Stacking Smarty with Quad X2
Old 01-27-2008, 01:59 PM
Big T's Avatar
What setting would you run on both?
With the commander do I loose some settings on the Quad?
Will the gas Misser work with the smarty and Quad together?
And last but most important I would still like to keep my tranny for another 2 years.
Old 01-27-2008, 02:13 PM
Sixxer's Avatar
I think you will need some tranny mods before stacking anything.
Old 01-27-2008, 02:22 PM
53 willys's Avatar
even more so if you want your trans to last....
shortbed rv's Avatar
Which Quad x2 do you have XZT,standard of race?Which Smarty do you have the senior A06 or the JR?
In any case you have to keep it turn down because of the trans and the big tires. It looks like you have at least several choices. Run the Smarty on even numbers and adjust the Quad on the fly or Download the pressure tune for the Quad and odd number for the Smarty. Quad will have more options coming soon.
Old 01-27-2008, 02:25 PM
53 willys's Avatar
Smarty alone can kill your trans...so why even bother stacking??? why not get your trans modded and buy just the smarty and then actually be able to run the Smarty on the higher SW#'s
my.02
Old 01-27-2008, 02:31 PM
Big T's Avatar
Can I get away with just TC and Vb truck only has 18000 miles on it.
Old 01-27-2008, 03:51 PM
Well, the problem is when you increase line pressure with a valve body and then use a triple dics TC to grab hard it places alot of stress on the input shaft. If you do not do boosted starts then go for it.
nvr-enuf
04-23-2011 12:43 AM
mpw8679
03-20-2009 06:18 PM
Big T
01-20-2008 12:18 PM
wap
13
04-27-2006 07:48 PM
JDGnut
07-18-2005 08:57 PM
Quick Reply: Stacking Smarty with Quad X2
