stacking question
Old Dec 30, 2007 | 08:18 PM
francis's Avatar
Question stacking question
i am going to get me a smarty jr in the moring and i am going to stack it on my dr. p pressure box stage 4. can i just leave me pressure box on and just load in the smarty jr or do i need to take it off. first then load the smarty jr.
and stacking the to how much smoke will i get out of the 2?
thanks james
Old Dec 30, 2007 | 08:59 PM
omaharam's Avatar
You do not need to unhook anything to download.
As for the smoke - you can tell us tomorrow.
Old Dec 30, 2007 | 09:43 PM
bluebull's Avatar
It's always been recommended to remove any module when downloading a programmer.
Cann't wait to see what everyone else says.
Old Dec 30, 2007 | 10:04 PM
RamWheelsBy4's Avatar
I have had timing and duration boxes stacked with pressure boxes and loaded and unloaded 4 different downloaders over the last two years without removing anything. I do try to turn off all electrical, radio, A/C, etc. But never had a problem with the boxes installed, they are not affecting any ECM readings with the engine off.
Old Dec 30, 2007 | 10:35 PM
omaharam's Avatar
Either Bob or Marco - can't remember which - has posted that you do not need to.
Old Dec 31, 2007 | 07:38 AM
bluebull's Avatar
Good to know.
Maybe I'am just outdated I know the older programmers and modules it was recommended as they could interfer with each other.
Old Dec 31, 2007 | 07:43 AM
bluebull's Avatar
That's good to know.
Thanks,
I would like to point out though and maybe doesn't make a hoot of difference but when a programmer is downloaded the ignition is required to be on which would send signal to the ECM and through the modules. Maybe I'am looking at it wrong. Maybe I'am just old and outdated.
Old Dec 31, 2007 | 10:20 AM
omaharam's Avatar
Good to know.
They still do put that in the instructions. It's basically to cover their butts, however, it is not a problem.
Old Dec 31, 2007 | 03:19 PM
CReed's Avatar
Plug and play no need in unistalling one or the other add the other. Heck you can even load a smarty tune in the truck then update it and then load over the tune in the truck. Smarty rocks. Hope you got a fuel system that Dr. P box isnt going to play well with the smarty without one dr. p by itself is bad about P0148 dtc.
Old Dec 31, 2007 | 04:08 PM
francis's Avatar
i have never had a problem with any codes from my dr.p it works great by its self. what is code p0148
just running the dr. p and cruseing about 75-80 iam getting 19.5-20.0 mpg with it .
i like it
Old Dec 31, 2007 | 04:33 PM
Thanks,
Well theoretically you are correct. But the thought of removing both a TST R49 and EZ just to load a program makes my hair curl among other things.
If you are scaird you can remove the box(es) first and then load the programmer, then put them back on. Caution is never a bad thing.
99 cummins
Jan 29, 2006 10:34 PM
Mike S
Nov 23, 2004 11:16 AM
gdh11
Oct 21, 2004 05:11 AM
Sarge1124
Feb 18, 2004 06:44 PM
