what to stack??
Old 02-24-2010, 11:08 PM
cowboy717's Avatar
what to stack??
ok. i'm still relatively new to the stacking concept. so what would be a better stack n why? smarty and tst... or smarty and mp-8?
Old 02-25-2010, 06:26 AM
CRToney's Avatar
If you are new to stacking be careful with stacking pressure boxes as some raise rail pressure more than others. High rail pressure kills injectors on these CR trucks. Smarty and TST are both excellent products.
Old 02-25-2010, 09:55 AM
rip 112's Avatar
The TST has some safeguards around it to help you be a safer operator with your truck.
But I have the mp-8 and have nothing but good things to say abut that in a stack. To me its fully controllable, the **** is direct and quick, and the power output is well noticeable. Spoolup is as fast as I like as well.
Old 02-25-2010, 10:38 AM
bullhauler05's Avatar
Smarty and quad X2 with r tune is good
Old 02-25-2010, 10:50 AM
carte89's Avatar
i like the smarty and the x2 as well. my rp never passes 26000. quick spool up too
Old 02-25-2010, 10:52 AM
DTR 1st Sergeant
soulezoo's Avatar
If it is a choice between TST and MP-8 I'd say TST.
First, TST will provide more power than the MP-8. Second, mp-8 is a pressure only box; depending on what TST model you get, they can adjust pressure too. So can the smarty. The TST can do it on the fly like an MP-8, just not as quickly or accurately. But the TST can do so much more.
Smarty/TST is a very strong stack on an 03-04. Be careful not to over do it and melt something. TST has to be used at lower levels, dependent on what smarty tune you are running. For example, if running TNT sw7-9, don't go over TST level 2/0. And do not add timing with TST if running timing with smarty. Just that 2/0 level can provide a tremendous increase over smarty alone depending on your supporting mods. Of course, if you are already maxing things out with smarty alone, you won't see much benefit with anything you stack with.
Topper
03-03-2008 10:17 AM
white250005
10-25-2007 10:19 PM
smoky beast
10-18-2006 06:58 AM
B.Law
16
04-22-2005 02:28 PM
Cat Cracker
07-14-2003 12:17 PM
Quick Reply: what to stack??
