Squeal coming from rear end wheels????
Old 09-11-2009, 05:38 PM
HorseHauler's Avatar
Question Squeal coming from rear end wheels????
Hey all,
I have just noticed a squeal coming from my rear end at the wheels. It is on both sides. I hear it when i start rolling and slowing down. It doesn't get louder with more speed. Could this be my U-Joints? Any other ideas??
Thanks all,
Eric
Old 09-12-2009, 01:08 PM
rich's Avatar
crap in the e brake maybe go wash the brake's out real good and see what happens
Old 09-12-2009, 01:16 PM
Thanks ill give that a try.
Old 09-13-2009, 11:17 AM
Spooler's Avatar
Check your rear pads for wear and make sure the caliper slides aren't stuck.
Old 09-17-2009, 08:14 AM
Update. I found the squeak, i believe it's coming from around the carrier bearing area... It squeaks in one spot as the drive shaft turns. Any new ideas???
Thanks all,
Eric
Old 09-17-2009, 09:16 AM
Spooler's Avatar
U-joint would be my guess. You've got one going out. Look for the red dust.
Old 09-17-2009, 10:18 AM
Thanks ill take a look at it. Any idea what one would cost?
Old 09-17-2009, 04:33 PM
BamaTJ's Avatar
I had a squeak in my rear when in reverse, it was the rear u joints. I changed them out a while back
Old 09-18-2009, 01:21 PM
SOhappy's Avatar
I did both of mine myself a couple of months ago (one was squeaking, needle bearings ground to dust), $35/ea IIRC for grease-able, lifetime warranty from Napa autoparts.
Not too bad a job but you'll need a big press to get them out of the yokes.
Old 09-18-2009, 03:48 PM
Thanks a lot, i'll take a look at napa. I'm def going with grease-able joints. Does anyone else have any preferences on which brand and wheres a good place to get them?? If anyone has links that would be awesome.
In case you cant tell im illiterate on this stuff!! lol. But i sure as heck am not paying the dealer 350.00 to replace 2 of them!!!
Old 09-18-2009, 06:38 PM
Well new update. I jacked the rear end of my truck up and got a better listen. Its definitely coming from the rear u-joint where its going into the rear end and not from around the carrier bearing. I just hope its still the u joint and not in the pumpkin
Old 09-18-2009, 10:07 PM
Big Show's Avatar
auto zone $9.99 2 year warrenty greasable
Old 09-19-2009, 01:06 AM
LeonT's Avatar
I have had the same problem with my rear tires squealing under acceleration. I just don't accelerate as hard now and the problem went away.
Old 09-19-2009, 03:13 PM
Spooler's Avatar
Don't cheap out and don't worry about getting greasable ones, those are the cheapies most of the time anyway. Get a set of Spicer u-joints pressed in and be done with it. The zerk fitting holes make them weaker that is why quality ones will not have them.
Old 09-19-2009, 03:54 PM
Big Show's Avatar
Thumbs up
Spicer from napa or duralast from autozone there all made by the same little guy in china so u could pay $25 extra for the name but what is that gonna do for yea
Quick Reply: Squeal coming from rear end wheels????
