View Full Version : Squeaky doors.... any suggestions?
For a few months now I have noticed a very annoying squeak on the drivers side door. Seems to be near the top back portion of the door. I keep the door sills and jams clean and have tried puttn' amor all on the rubber around the doors. This seems to help and it never goes away. With in a few weeks it's back again as loud as ever. Really makes the truck sound cheap. I havn't tried anything on the doors other than armorall .. I have not waxed the truck in a while either. What's the fix?? Thanks.
dodgediesel4x4
07-15-2004, 11:14 PM
Never tried this, but it would do nothing but help.
http://www.dieseltruckresource.com/faq/faq.php?display=faq&nr=113&catnr=16&prog=1&lang=en&onlynewfaq=1
BigBlue
07-16-2004, 02:05 AM
I and several other's feel your pain. I've had most of my dash off trying to fix a squeak in the same area your having problems. No one's ever figured it out. I usually spray a huge amount of silicone on the steering wheel shaft under the dash and that helps for a little while.
dodgeram
07-16-2004, 04:43 AM
I found silicone spray works for a while ..just respray the rubbers every once in a while
problem is the cab flexex and stuff rubs N squeaks there's not much you can do to stop that other than lube it up
