Spring Compressor or No Spring Compressor?
Hey guys,
I purchased a leveling kit and intend on installing it this weekend. I searched the forums but did not find a definitive answer on whether compressors are necessary. I know they arent the safest and most of the ones you can "rent" are not made for our springs. SO, Can I install this kit with just a crowbar and some brute force or will i need compressors? Thanx for your help!
you dont ned the spring compressors. when you go to insall, lift the frame, let the axel drop, you may have to un bolt the top suspensio arm to get enough travel. with everything unbolted, the axel will lower enough to slip your old out and new springs in.
Camarogenius
06-25-2007 08:55 PM
