split manifold/ header?
Old Dec 8, 2009 | 08:08 PM
W150CTDproject's Avatar
Anyone ever see or DO this? (the header i mean). i wonder what it would sound like with 4" exhaust
http://www.youtube.com/watch?v=RmPmL6l6F_8
Old Dec 8, 2009 | 08:44 PM
jesussaves's Avatar
http://www.honda-tech.com/showthread...hlight=cummins
equal lenght turbo manifold produce way more power and lower egts
Old Dec 8, 2009 | 08:46 PM
jesussaves's Avatar
http://lovefab.net/?page_id=295
Old Dec 9, 2009 | 10:21 AM
Bigone721's Avatar
You usually never see tube headers on diesel engines because the vibration of the engine will, in time, cause the tubes to crack. Any time you run a header on a diesel you need to run supports to the header flange to keep it from cracking the tubes. I can almost guarantee that the header in the video and the one on the twin setup will fail by the tubes breaking.
You used to see some people running headers on 6.2 GM's and the 6.9 and 7.3 Internationals, but they had no turbos. I've also seen some semis with headers but they were just drag trucks.
The second one listed in the Honda forum looks like an overall good design. He has the tubes very close to equal lenth, the tubes follow different routes on either side of the flange (helps resist cracking and better supports the weight of the turbo), and he used a thick flange at the head that runs the full lenth. The only big problem I can see with it is he used what looks like pipe elbow on some of the bends which will drastically cut down on flow because they are a thicker wall than the tubing.
I would only consider running a tube header on a diesel for competition only. If you ran one on a DD I don't think you could get it to last.
Old Dec 9, 2009 | 11:31 AM
ppiggppenn's Avatar
I'm just glad that's not me or my engine, ... no sign of engine cooling or ear protection, ....
Old Dec 9, 2009 | 04:28 PM
CONFEDERATESON's Avatar
^^i agree totally! he ran that thing like an moron,disreguarding safety compleatly.i dont think people like that should be able to own a cummins. but sadly anyone with the money can buy whatever they want reguardless of weither they deserve it or not.
Old Dec 9, 2009 | 05:06 PM
speed75's Avatar
I would think if u made it out of stainless pipe and fittings it would probably last awile
Old Dec 10, 2009 | 10:45 AM
i just thought it was odd for a cummins to have a header lol ill for sure stick with a BD or ATS manifold but i thought id just show this little piece of "treasure" ahhaha
madhat
18
Feb 6, 2015 12:32 AM
jt
45
Jun 26, 2007 02:52 PM
MCMLV
28
Dec 23, 2003 06:19 AM
May 16, 2003 01:56 PM
SjLingenfelter
Mar 14, 2003 09:50 PM
