spicer ball joint question-which ones???
Old 05-16-2007, 05:09 PM
rjm022's Avatar
need upper and lower ball joints. spicer lists four different types of upper ball joints!!! 1) non-adjustable 2) adjustable, 1/2 degree positve/negative camber/caster.3) adjustable,1 degree and 4) adjustable 1 1/2 degrees! which ones do i need.should get???? thanks.
Old 05-16-2007, 11:28 PM
mudslinger's Avatar
It sucks, but I did it with 2 alignments. I had the truck aligned, then took those specs to order the correct offset. Then had the toe re-adjusted after the ball joint work. I believe that is the only way to correct a camber problem though. You could be taking a chance getting the 0 offset and then having it out of adjustment.
Old 05-20-2007, 12:54 PM
rjm022's Avatar
which ball joints did you get??
Old 05-21-2007, 03:22 AM
pullin hard's Avatar
buy the stock off set, you run no lift, if you were running a lift, then thats a different story
Old 05-21-2007, 04:16 AM
mudslinger's Avatar
I am running a 1.5* left and a 1* right. My tires have always been off regardless of lift. The drivers side you could see the camber by looking at it. They spin to adjust so you can use them to address camber or caster. With the way these trucks are setup I don't think a lift really has an effect on camber. Everything is square now.
Mexstan
12-02-2012 06:28 PM
wcbcruzer
22
04-30-2008 06:58 PM
B.A.Ram
02-14-2006 09:41 PM
Tim9712v
01-24-2005 05:22 PM
Quick Reply: spicer ball joint question-which ones???
