Speedometer & Wipers not working(?)
Old 08-26-2011, 08:02 PM
xxwildbillxx's Avatar
Trying to figure out why speedometer & wipers will not function... plus the ABS & Parking Brake indicator lights are on full-time? Also notice general glitchy movement of some of the analog gauge needles???
Old 09-30-2011, 12:21 AM
Problem solved...
Spent some time poking around under the hood pushing/pulling on things and lucky enough, happened to tug on a wire cluster which led back to a slightly loose and corroded ground screw! Uploaded a photo for reference... its the ground screw touching the tip of the orange clamp (located on driver side fender rail).
Attached Thumbnails Speedometer & Wipers not working(?)-corroded-loose-ground-screw.jpg
Sleigher
05-04-2017 02:12 PM
don60
05-30-2010 01:20 AM
Grant711
09-07-2008 09:34 PM
halerazor
01-03-2005 10:51 PM
Quick Reply: Speedometer & Wipers not working(?)
