Speedometer correction
Old 03-14-2007, 08:01 AM
kfm61's Avatar
Any one have suggestions on how to correct my speedometer reading? I have a 97 auto and went from 3:55's to 4:10's. Do I change the gear at the back of the transfer case, re-calibrated, or both?
Old 03-14-2007, 10:26 AM
Captain's Avatar
is it 4wd? I thought the 94-97's had the speed taken from a gear in the tailshaft of either the trans or the transfer case? you just need the correct gear.
Old 03-14-2007, 01:02 PM
HRDROKN's Avatar
I installed a re-calibration box from superlift.... best part is that it is fully adjustable! It also has two settings for two different tire sizes for those of you that switch tire sizes... just flip the switch.
Old 03-14-2007, 03:11 PM
pete97's Avatar
You are correct. My 1997 gets the speed-o from the a gear in the tail shaft of the T-Case.
Old 03-14-2007, 04:12 PM
Scramblinman's Avatar
How do you determine/calculate which speedometer drive gear to use?
Old 03-14-2007, 09:15 PM
kfm61's Avatar
Mine is a 4WD. I thought as you confirmed, the signal is from the gear in the tail shaft housing on the transfer case. I have the same question as Scramblinman, how do I determine which gear to use?
seralan
03-02-2006 04:20 PM
98 2500
02-29-2004 12:15 AM
commando
20
04-26-2003 06:30 AM
ridofpwrstroke
03-08-2003 12:18 AM
ridofpwrstroke
03-07-2003 07:08 PM
Quick Reply: Speedometer correction
