speedo recal on 06
Old 03-28-2007, 07:35 PM
wreedCTD's Avatar
speedo recal on 06
OK can the dealer reprogram the speedo on a 06 or not? i have heard several people say they cannot anymore on the 06+ trucks.
Old 03-28-2007, 09:36 PM
m2fsr's Avatar
My dealer reprogrammed my speedometer for the larger tires I had put on.
Old 03-28-2007, 09:41 PM
wreedCTD's Avatar
what size did you go with???
Old 03-28-2007, 09:54 PM
m2fsr's Avatar
I have a set of 305's right now
Old 03-28-2007, 09:55 PM
wreedCTD's Avatar
got any pics that is what i am going to go with?
also have you tested the speedo against a gps to see how accurate it is?
Old 03-28-2007, 10:15 PM
53 willys's Avatar
they don't have 315's programmed into the computer for some reason??? the biggest tire the dealer can program on a 06 is 285's
smarty can do what ever size you want as far as I know.....
Old 03-28-2007, 10:33 PM
wreedCTD's Avatar
arnt 285s and 305s the same size?
Old 03-28-2007, 10:55 PM
Jmac's Avatar
What you do is measure roll out. Mark the tire and ground at exactly the same spot, roll the truck one full tire revolution mark the ground again. measure the distance in inches. Unless my math is wrong, there is 63,360 inches in a mile. Soo lets say your rollout is 105.5" 63360/105.5 rounded up should be 601, same as a 315 BFG. Measure them hot after driving a while b/c hot air expands and tire revs will change with the higher air pressure.
This was has been acurate for me every time. The dealer can adjust any tire size by selecting "other" on the handheld machine and punching in the revs per mile.
Hope this helps.
Jamie
Old 03-28-2007, 10:58 PM
wreedCTD's Avatar
Hope this helps.
Jamie
wow what a great idea! i would just hate to have the dealer charge me $90 and have it programmed in wrong! are the revs per mile on bfgs website correct????
Old 03-29-2007, 07:39 AM
duddin10's Avatar
They programmed my dads for his 35 x 13.5x 20 wheels. They told him they only have a few update sizes to try. They used the update for the largest tires they had on file. It's still not enough. He is waiting for the diablosport predator update to be released and then he is gonna buy one of them.
Old 03-29-2007, 08:01 AM
DTR's 'Go to Guy'
vzdude's Avatar
The dealer needs to know revolutions per mile. They can program most realistic tire sizes with that. I can't remember what the max is, but they can go up 2 or 3 sizes. More than that and you need an aftermarket downloader.
Old 03-29-2007, 09:01 AM
53 willys's Avatar
I took my revs per mile in and they said they did not need it.....my dealer could not get 315's programed in on my truck...they did 285's the biggest the 06 computer would allow????
revs per mile for a 315/70/17=586.9
http://swatt.j.porter.name/tech-cent...ire-calculator
so is my dealer lieing and I need to take it in or is your dealer lieing about setting it to the right size????????
Old 03-29-2007, 09:23 AM
UnrulyNFS's Avatar
The smarty is the only way I know how to program. But you have to own the smarty I think.
I'm rollin on 40's and its right on with my GPS.
Old 03-29-2007, 10:12 AM
K5KRAZIE's Avatar
Superchips will do it as well. Just put one of their programmers into my truck. Still messing with it.
Old 03-29-2007, 02:50 PM
Jmac's Avatar
Again it all depends on air pressure and roll out. but yes basically the numbers are usually close enough for govt. work.
Jamie
Quick Reply: speedo recal on 06
