speed sensor has issues
Old 12-23-2003, 04:12 PM
gutless's Avatar
helllo to all!
1994 4x4 ctd auto
started out with tack going out when engine was cold.
now tack and speedometer go out intermitenly.
can sometimes get all back by restarting but less often,
both will go out while running,with engine warm and
restarting at 45mph and getting in to overdrive before tack
goes out it will stay working all day no matter how many times
I shutdown???
speed sensor has 3 wires 8volt,5volt,and ground all good.
after serching at tdr I spliced into ground wire and went
to block and battery.no change.
can the sensor be bad and still work?
why would the speedo go out?
could it be a bad ground at pcm?
thanks, bill
Old 12-27-2003, 08:31 PM
gutless's Avatar
ok so I changed speed sensor $110. and tack has gone out once
in 2 days.
Has any one here had abad body ground or pcm ground?
If so what did you do to fix it?
has any one had a problem like this?
Old 12-29-2003, 12:20 AM
gutless's Avatar
lost 8 volt,now reads 1.8 at vss [speedo] and .7 at crank speed
sensor.
any help?
has any one had a problem w/ pcm?
thanks
GUMP
05-26-2008 08:26 PM
jtalaiver
20
06-22-2007 10:36 AM
sjester
05-10-2007 05:03 PM
FDX
01-15-2007 01:47 PM
KC
01-10-2003 11:25 PM
Quick Reply: speed sensor has issues
