Speed limiter
Old 06-16-2007, 04:11 PM
Allways_Lost's Avatar
Speed limiter
I have the bully dog in my sig and i just found out the hard way that it doesnt disable the speed limiter. I was looking for a way to get rid of the thing. Is there another module that it could stack with it? What are my options without removing the bully dog?
Old 06-16-2007, 05:23 PM
Keyser Soze's Avatar
I know BD makes one, i dont know if they make one for the 07's tho..
Old 06-16-2007, 05:45 PM
RunninLean's Avatar
You and alot of others are waiting for this product for the 06 and newer. My self included. The turn key to start trick does not work for us either.
Old 06-17-2007, 11:24 AM
CookieMonster's Avatar
Just curious, could you recalibrate the tire size to the smallest one possible?
It might fool the computer into thinking the truck is going slower than it actually is.
Old 06-17-2007, 11:46 AM
CReed's Avatar
Nobodies got it yet for the 06-07 trucks sorry, soon hopefully if you are that anxious and cant wait pull your abs fues, you wont have use of guages or abs but you can go way faster then 109. Or you can wire a ground into the abs wiring and ground it out so all you gta do is flip the switch to go fast and turn it off and have guages and abs.
Old 06-17-2007, 08:11 PM
duallydave's Avatar
i would be carful about wiring the abs to ground,another member did somthing similar and fried his ecm,now wiring a switch on the abs wire just to open and close the circuit is ok,i have mine done like that,but i wouldnt wire the switch to ground.
Old 06-18-2007, 07:51 PM
CReed's Avatar
Ya i believe your talking about phil baxter his ecm fried b/c they got trigger happy with test light trying to find the right wire and didnt tape back over the holes and the got wet and shorted out. So how do you have your system setup duallydave open and close the circuit? Just an intermidiary switch or what?
Old 06-18-2007, 09:46 PM
ramtd02's Avatar
What I do is recalibrate the ECM for smaller tires, I figured out the vehicle speed per 100 rpm, then re-size the tires. The if/when I hit 3450 I know i am moving @ 122.7 mph, instead of only hitting 108-110.
Old 06-19-2007, 08:50 AM
duallydave's Avatar
Talking
just cut the abs wire and splice the switch in place of the 2 wires,just opens and closes the circuit,i was to scared to ground the wire.with my predator and the switch open it seems like i have less power,diablo says it has nothing to do with thier programming.do a search for the right wire.
Old 06-19-2007, 11:25 AM
cquestad's Avatar
More on interrupting the ABS signal please....
Does it just kill the Speedo?
Where did you splice the switch in? Do a relay?
Old 06-19-2007, 12:09 PM
Bud Kunz's Avatar
The latest Bully Dog Power Pup for the 6.7L has a speed limiter adjust up to 135MPH and it works on all Cummins back to 2003. Should be on the next Triple Dog Update Too.
Old 06-19-2007, 12:13 PM
cquestad's Avatar
Rut Ruh...
Marco/Bob...please stand up!
Old 06-19-2007, 12:56 PM
Armapoc's Avatar
Nice, Can't wait to try it out. Triple Dog gonna have it soon?
CrashCade
07-05-2005 01:32 AM
dieselrob
13
04-09-2005 10:48 AM
lit up
11-27-2004 11:36 PM
ARAcummins
10-24-2004 09:30 PM
Ttexas25
31
09-30-2004 08:48 AM
Quick Reply: Speed limiter
