Spare tire winch won't keep the tire tight.
Old 05-12-2006, 04:34 PM
I PASS GAS's Avatar
I have a 4" dual exhaust system from Rip Rook. My spare tire winch backed off and the tire ended up swinging by the cable. The pipes pass so close to the spare that it swinging by the cable broke the weld on one of the hangars. Is there a way to tighten that thing up so it won't back off, or do I need to replace it. Even after I crank it down until it clicks several times, it still won't get it snug up against the frame.
Old 05-12-2006, 07:15 PM
Danderson's Avatar
You'll need to replace it! The part was replaced under warranty on mine. retail is only $65.00. Do a search as there are some discount sites for mopar parts.
Old 05-12-2006, 09:55 PM
I PASS GAS's Avatar
Do you know specifically what it is called?
Old 05-12-2006, 10:57 PM
yfz450guy's Avatar
it is the "spare tire hanger downer picker upper"
just jokin' i am not really sure never known one to go bad. but if you tell you need the crank assy. for the spare tire on " insert make and model here" they should have no trouble figuring it out.
Old 05-12-2006, 11:19 PM
Danderson's Avatar
I think it's called the spare tire winch. When I go off road again I'm going to install a "Master" brand cable lock. Don't trust the winch. I crawled under my wife's company Ford an lo and behold,same product.
Tallguy67
16
09-18-2015 08:39 AM
Hodge
05-04-2012 07:27 PM
Tallguy67
04-11-2011 02:46 PM
Junkdude
02-09-2011 03:15 PM
Joseph H. Smith
06-14-2007 08:18 PM
Quick Reply: Spare tire winch won't keep the tire tight.
