Southbend clutches 4BT powered mud racer
Old 04-21-2009, 12:53 PM
Iron Pony's Avatar
I seen a short wright up in Diesel Power Mag about Southbends 4BT powered mud racer. I have plans to hot rod a 4BT and would like to hear from anyone that has seen this machine. Or knows anything about it. Or has built up a 4BT. I am looking to try and get 400+ hp from it. And I think that about anything that works on a 12v should work on the 4BT. The engine I have is 130 hp inline pump model. I would try compound turbos, fireringing and studing the head. And having Shield do the pump. Any suggestions are more than welcome. Thanks
Old 04-21-2009, 06:43 PM
patdaly's Avatar
400+ should not be an issue.
Check out the SBC clutch website, I believe they still have the video up.
I think Piers built the engine for them......
Old 04-21-2009, 10:09 PM
Bluedually4x4's Avatar
The 4bt is exactly the same engine as the 6bt engine minus the two center cylinders. Bell housings and accessory brackets are all the same.
Old 04-23-2009, 02:40 PM
13FOX's Avatar
IMO I would have CDS do the pump work.
Old 04-23-2009, 11:49 PM
turboguy121's Avatar
you should be able to get alot more than 400hp out of it. There will be a couple 4b rangers down at ts drag racing that are close to 800hp
Old 04-24-2009, 08:24 AM
Vendor - Former Vendor
South Bend Clutch's Avatar
Feel free to call us and we can head you in the right directions.
800-988-4345
Peter
Chance
Cummins Conversions
02-23-2011 05:05 PM
JIT
11-02-2007 11:24 PM
SolarYellow05
16
04-23-2007 07:16 AM
MikeJ
05-16-2006 11:16 PM
Superduty12v
10-05-2002 01:35 PM
Quick Reply: Southbend clutches 4BT powered mud racer
