South Bend DD 3850 question
Old 08-09-2008, 11:48 PM
Snoxracer's Avatar
Well just got back from a local pull and the first hook on the new clutch and injectors. The truck ran really good and the clutch seemed to work great, right up to the end of the pull. Once we got to the end of the track it spun out and pushed the clutch in and everything seemed normal. Then pulled off the track, stopped and couldn't get it in to gear. Had to shut off truck and then restart in gear and took off. I then just worked the clutch a bunch of times, foward, reverse a bunch of times and then it seemed normal again.
Second pull it didn't seem to do it as bad but did it a little.
What could be causing this, just need to get some time on it? We probably had 75 miles on it of just driving it before this pull. Anybody else have and problems llike these.
Thanks for your help!
Dustin
Old 08-10-2008, 09:29 AM
dieselrob's Avatar
Thats from not being broken in, and getting it hot the plates prolly stuck together. Get more miles on it in stop and go traffic.
Old 08-10-2008, 12:55 PM
98.5Hotrod's Avatar
You should break that clutch in before pulling it. Peter told me about 200 miles of normal driving.
Old 08-10-2008, 01:52 PM
ct2500's Avatar
there is no brake in on a daul disc. clutch just got hot and stuck.
Old 08-10-2008, 04:51 PM
98.5Hotrod's Avatar
I'm just telling you what Peter the owner of Southbend Clutch told me. Not all DD clutch are of the same materials.
Old 08-10-2008, 09:48 PM
Snoxracer's Avatar
So how do they break in a full blown pulling truck if they cant drive in stop and go.
I thought that it might of stuck but I would of thought that it would of don't when unhooking from the sled. But I was able to get it into reverse and the back in to 1st to drive off the track. Thats when it would release?
Thanks for the replys
Dustin
Old 08-11-2008, 08:00 AM
Ph4tty's Avatar
Generally in stop and go traffic you're not launching from high rpms and slipping the clutch for a long time. The longer you let it slip the hotter it gets. Three seconds or less of slipping it should be fine. Maybe try a lower gear next time or get some launching advice from some other pullers.
Old 08-11-2008, 06:07 PM
haloman's Avatar
guys in the Big HP pulling trucks have the resources/sponsors to replace the clutch every season. I assume most of us want our clutches to last longer than that. So just break it in with some city driving.
Bswope
17
03-03-2008 07:21 PM
ddestruel
02-28-2008 03:05 PM
SmokenRam
10-18-2006 10:32 PM
D.Wiggs
10-06-2006 12:52 PM
Big Smoky
03-31-2005 01:22 PM
Quick Reply: South Bend DD 3850 question
