Source for eldorado calipers
Old Jul 26, 2009 | 08:14 PM
APD's Avatar
APD
I want to do a rear disc brake conversion and Im looking for eldorado calipers so I can keep my parking brake. All the online places show pictures of the caliper without the parking brake bracket & spring. Is this a separate part that I can purchase or do they usually come with the bracket?
Anyone know of a good price on these calipers with the bracket? My search has found a range from $70-150, but I dont know if the bracket is included. Thanks in advance.
Old Jul 26, 2009 | 09:24 PM
BC847's Avatar
1st Generation Admin
The bracket is a separate item.
I got my PB bracket and springs from the local auto salvage yard. If you can find an eldorado then be sure to grab the calipers as well for a core trade-in on rebuilt ones from most any regular parts house.
Old Jul 26, 2009 | 10:45 PM
sdstriper's Avatar
rock-auto
Old Jul 27, 2009 | 07:32 PM
NoFrills's Avatar
speedway motors has new ones
Old Jul 27, 2009 | 08:13 PM
BC847's Avatar
Ultimately I had to find a bracket that would mount to the caliper, and with a little modification, have it fit the PB cable sheath of the Dodge truck . . . .
Old Jul 27, 2009 | 08:37 PM
sdstriper's Avatar
BC847, Which Caliper bracket did you chose? Not the PB bracket, the caliper...
Old Jul 27, 2009 | 08:57 PM
BC847's Avatar
I got the brackets (kit) from these folks . . . http://www.egrbrakes.com/index-main.htm
This piece goes on first . . .
Then this piece . . . .
Old Jul 27, 2009 | 09:04 PM
sdstriper's Avatar
Looks like nice stuff.
Old Jul 28, 2009 | 09:00 AM
APD's Avatar
APD
bc847- where did you get the PB lever & spring???
I have found all the other parts I need for the conversion, I just cant find the PB lever & spring.
I have found some new TSM calipers with the lever/spring, but they are $320/pair....too expensive.
Interestingly, in my search I have found that the 1985 cadillac eldorado calipers come with the PB lever/spring....but I hesitate to use those calipers because the 85 was a lighter car and I think the caliper is smaller.
Old Jan 15, 2018 | 01:37 PM
1stGEN'93's Avatar
Shouldn't the bleeder be positioned on top of the caliper at the highest point? I thought that was the only way you could get all the air out.
Old Jan 15, 2018 | 02:34 PM
death row dave's Avatar
Bleeder
Bleeders should be at the top of the caliper when mounted . These look to be installed incorrectly in this photo
Old Jan 15, 2018 | 05:41 PM
samiam4's Avatar
I was at the tire store and someone with a very new Buick cross-over and what appears to be the same style caliper as the old eldorado's. I would look hard at the newer GM stuff.
M
Old Jan 15, 2018 | 08:57 PM
BC847's Avatar
The goal was to install the calipers so that they'd be up and out of harms way, if you will. I had to remove the calipers and hold upright to bleed them. Takes five minutes longer.
The more traditional mounting would have you swap sides with the calipers, and reposition the brackets such that the calipers would be just forward of straight down. The bleed ports would then be straight up and the PB cables would look forward as they should.
Old Jan 16, 2018 | 02:30 AM
maybe368's Avatar
The literature that came with the EGR kit specifically says to remove the calipers in order to completely remove all the air from the El Dorado calipers and it says that this is the only way. If that is the case, then it doesn't really need to be mounted upright, 5 minutes sounds about right. It is really important to use the parking brake as this is how these caliper adjusts itself, they are a different animal ...Mark
Old Jan 16, 2018 | 11:05 AM
Danderson's Avatar
I had the entire EGR disc conversion on my 2nd. It yielded marginally better stopping power and a lousy parking brake.
