What is soot in an oil analysis?
Old 02-08-2012, 01:53 PM
Shorts's Avatar
I'm looking at an oil analysis from Blackstone I did last summer. If was curious about how much soot is in my engine oil, what do I look at to find that out? Is that even possible?
Old 02-08-2012, 02:08 PM
Shorts's Avatar
Hah, search first, post second It is % insoluables.
Found a thread: https://www.dieseltruckresource.com/...s-t116087.html
Old 02-08-2012, 07:17 PM
Hvytrkmech's Avatar
Yes yes and yes. Soot is a byproduct of combustion taken from the cylinder walls by the engine oil. A good quality oil will hold the soot in suspension till the next service interval with minimal impact on service life to teardown. A poor quality oil will do the opposite. Soot is an abrasive so the smaller the % the better.
De nada,,,
Old 02-08-2012, 08:38 PM
carl48's Avatar
the ci4 oil was formulated to hold 5% in suspension. the 6.7 required a reformulation to lower the stuff the dpf could not burn off and hold 2% more carbon in suspension. the new oil is cj4. if you have a 04.5 up through the 6.7 you should run a bypass filter. and on a 6.7 you need to do all of the deletes asap
Old 02-09-2012, 09:53 AM
Shorts's Avatar
Thanks guys.
ctd4stan
05-05-2011 10:39 PM
92smokin blacky
01-25-2011 11:36 PM
Baja
02-12-2007 10:58 AM
Bobcat698
11-01-2005 07:05 PM
Quick Reply: What is soot in an oil analysis?
