Some Questions
Old 02-27-2010, 10:55 PM
SMKHZRD's Avatar
Some Questions
Hey guys i just got twins on and hit about 55 psi. What is the the highest boost we can run before i need to stud it? Also does ur trucks haze pretty bad. I am trying to figure out if there is aftermarket injectors in it. It hazes bad even before i put on the smarty and twins. Also do u guys think i can run the tnt tune with my twins? For the guys who have twins what boost u guys running?
Old 02-28-2010, 01:24 AM
Administrator/Jarhead
madhat's Avatar
Tuning twins means a lot. You have a lot of training to do on them.
My sticks haze when they are cold, and it's normal.
Old 02-28-2010, 10:54 AM
SMKHZRD's Avatar
So its normal for aftermarket sticks to haze kool.. but what about stock stick?
Old 02-28-2010, 11:16 AM
madhat's Avatar
Maybe. If you've been running a lot of pressure to them over time the tips are probably worn a bit...
If you are over 45, you need studs. You can torque down your stock head bolts, however, you are living on borrowed time on that.
You should be able to run the TNT. If it don't work, change it back!
morkable
ABDTR #5
19
12-18-2009 07:45 PM
TxDiesel007
11-29-2006 12:08 PM
SilverHoss99
10-31-2005 07:22 PM
JKM
03-04-2005 03:33 PM
drawson
11-12-2002 06:35 PM
Quick Reply: Some Questions
