danimal 95
02-22-2010, 05:58 PM
getting these codes
p0633,p0602 and p0107
they all came on in in a matter of 1 week,and i cant clear 2 of them with my diablo.i alredy used the search but there really wasnt any definative info.it starts and runs fine but under acceleration it will buck once at about 2k rpm then it seems to lose power,if i roll on the gas slowly it accelerates fine???i have already looked at the wiring for the MAP sensor code and it is clean with out ant corrosion,i also removed the edge programmar to eliminate any issues with that,i guess i should put the stock file from the diablo in it as well.any thought would be appreciated
