Smoke vs. Boost vs. Fuel
Old 02-02-2010, 12:18 PM
sheriffav8r's Avatar
So, here's my question: If I run my Juice at 4x5 or 5x5 I get a lot of smoke. Since, I believe, smoke equals unburnt fuel, does that mean that I need a larger turbo and run that at a point to where I stop seeing smoke and only then would I need bigger injectors? Most guys say that injectors would be needed before a larger turbo (my tiny HY35 whistler), but it would seem that I need a larger turbo first....
Old 02-02-2010, 02:52 PM
BigErksG2's Avatar
Depends on what you want: quick spooling, top end, towing. If you get one thing, you take away from another. What do you do with your truck? The HY turbos are very small on the turbine side and can choke out a modded truck quickly so you can go a little bigger without sacrificing much spoolup but keep in mind what you want to have in the end so you can build it right the first time. Switching turbos 2 or 3 times is quite costly.
Old 02-02-2010, 04:44 PM
Yeah, I don't foresee going much over 400HP. It's a daily driver that hauls a light camper every once in awhile. Right now I'm looking for an HX-35/40 hybrid. But my HY does spool nicely to 35psi, though.... I guess I'm subconsciously trying to blow it up so I can rationalize a nice new turbo.... (especially to my wife: "Sorry, honey, but I have to replace my turbo. Just the cost of doing business, you understand....)
Old 02-03-2010, 11:26 AM
JIT
JIT's Avatar
The perfect mix of air and fuel would be a light grey haze at wide open throttle! You will always have some smoke at low boost but once the turbo lights it should clear up. An HX35 from a manual truck with an adjustable boost elbow would be a good cheap upgrade for your truck. 35-38psi in stock form... and then you can get a small set of injectors if you want more.
Old 02-03-2010, 03:20 PM
That's the plan, Stan....
D.Wiggs
01-04-2007 04:24 PM
dhe9
11-14-2003 07:31 AM
PK
10-19-2003 10:28 AM
jbs007
07-08-2003 01:29 AM
97CTD
03-17-2003 08:14 PM
Quick Reply: Smoke vs. Boost vs. Fuel
