smoke switch troubles!
Old 08-04-2008, 11:15 PM
mt_rodeo's Avatar
so after reading quite a bit on here, and watching this vid: http://www.youtube.com/watch?v=QVRPipmo8sU
i decided to install a smoke switch tonight. i hooked it up on the wires shown on the vid ( no edge mod. tho) and tried it out, and all it did was throw a code and lose power. no smoke. does the switch not work on stock truck? the code is no worry, i sell cars for a dodge dealership so i can get the code scanned and cleared. i am just concerned about losing power and not gaining smoke. what did i do?
Old 08-04-2008, 11:40 PM
JPR Ram's Avatar
Location: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
No a smoke switch will not work on a stock truck. It'll just go into limp mode as you have found out. A module that does boost fooling is necessary.
Old 08-05-2008, 12:01 AM
mt_rodeo's Avatar
do i have to unhook and clear code to come out of limp mode? or just unhook it?
Old 08-05-2008, 10:09 AM
dodgezilla04's Avatar
if you go to the wrong wire, you are hooking into the temp sensor wire, and it will throw a code and loose power, i did it wrong the first time when i had a switch......
Old 08-05-2008, 11:51 AM
JPR Ram's Avatar
Yes, you wll need to unhook the jumper you installed so you can clear the code.
Old 08-05-2008, 08:45 PM
mt_rodeo's Avatar
update: pulled the switch and wires late last night, check engine light still on this morning when i went to work, but truck was out of limp mode at least. cleared DTC when i got to work and now we're back to good. next time i'll do more research b4 tying wires together. thanks everyone for the help.
texaspsdx
01-21-2014 11:37 AM
Nick & Kels 08
12-26-2010 09:26 PM
mopar65pa
07-12-2008 06:40 PM
SPLnut
12-31-2007 11:27 AM
redramnc
03-28-2005 06:58 AM
Quick Reply: smoke switch troubles!
