Smarty to be used to adjust speedometer on 98.5 12 valve?
Old 06-28-2007, 07:24 AM
jsflagstad's Avatar
I have a smarty for the 2nd gen 24v CTD. Can I use it to adjust the speedometer on a 98.5 12 valve? I have a friend that just went up 3 sizes in tires and he needs this done.
Anyone done it? Bob, do you know?
Thanks,
Old 06-28-2007, 08:01 AM
AggieJustin's Avatar
The tire size programming only stays with the truck as long as you have a Smarty program loaded, I believe it wipes out once you go back to Stock.
And I doubt it would sync up to the 12V, since the ECM would be much different and there would be no chance of programming it.
Old 06-28-2007, 12:04 PM
graphitecumnz's Avatar
Even if the unit would communicate with the truck, Justin is correct... The ABS adjustment only works if you load a Smarty software, stock means stock.... not even the ABS adjustment stays.
Old 06-28-2007, 02:41 PM
CTD NUT's Avatar
Another thing to remember is that there is no 98.5 12v....only a 98. There is NO ECM on a 98 12v! Only a PCM to run the dash, charging system and auto tranny if equipped. So, there isn't even anything for the Smarty to talk to.
Old 06-29-2007, 11:09 AM
And that answers the question I had in the back of my mind when I posted.
Wasn't sure if there was no ECM at all, or just much different since it had no electronic injection pump to control.
Old 08-01-2009, 08:10 AM
DRM
DRM's Avatar
Sorry about digging this up, but I just threw some H2 take-off tires & wheels on my 98 12v and now the speedo is waaaaaaay off (77mph reads 60!).
So if it's not an electronic change - how do you make the adjustment?
Old 08-01-2009, 02:06 PM
Tate's Avatar
Need a DRB III scanner to change it.
rogerL1961
07-16-2007 05:58 PM
03quadduallyho
06-25-2006 09:32 AM
DieselJoe
04-27-2006 05:06 PM
towin1JT
08-06-2003 09:09 AM
Quick Reply: Smarty to be used to adjust speedometer on 98.5 12 valve?
