Smarty tuning questions.....
Old 09-01-2009, 07:32 AM
SLVR bullet's Avatar
Let me start off by saying that all the differant settings on the Sr. have me a little nervous but with a little help from you guys i should be in great shape...Thanks in Advance so here is the question:
What would be a good place to start for mileage/seat-o-the pants meter on the Sr. with Revo tunes? I am not sure where to start & have read on here that you can really tear your tranny up if you TM is not set properly. I dont feel like spending any more $$ on my tranny @ this point in time. Also, would it be ok to haul lighter loads say in the 5-7k range. Thanks again for any advice in getting this set-up properly.
Old 09-01-2009, 07:34 AM
this will be 4 the truck in my signature.....i will be removing the Predator & Striker II (obviously) & i have since put the muffler back on.
Old 09-01-2009, 09:23 AM
DTR 1st Sergeant
soulezoo's Avatar
To save the tranny don't go over 1 or 2 on the TM (torque management) setting.
For best mileage, go with highest timing you can run. As far as the power level settings, it is different truck to truck. I have always had my best mileage between sw 5-7 on most smarty tunes. But that is just me, others report sw 1... sw9... get the picture?
You can run whatever load you like if you are not mashing the pedal hard all the time!
Old 09-01-2009, 11:47 AM
is TM 1 less torque management( closer to factory setting ) than 2 or is it the other way around... i have read some posts saying the numerically the #`s are backwards ...ie. 1 is more 3 is less type of thing.
Old 09-01-2009, 01:25 PM
DTR 1st Sergeant
soulezoo's Avatar
You are looking at the timing which is "3 is less than 2" but on regular Revo, 4 is the most...
On TM, 1 is most, or mildest, 4 is least, or wildest--- 4 is hardest on tranny.
BIGDAN65
02-18-2009 05:43 PM
nottanuff03
01-13-2009 09:33 AM
mainiac
10-15-2008 09:35 AM
MegaCabRam
08-08-2008 02:01 PM
Bswope
05-05-2008 05:53 PM
Quick Reply: Smarty tuning questions.....
