SMARTY, Stage 2 CP3, Flux1 DYNO
3 pulls, all 3 had smarty on level 9 and then used the ts mp8 to play with some pressure. here are the results all done on a superflow load dyno:
Smarty 9 No Pressure
COLUMN MAXIMUMS
Test: 33107JuddMcLure1
STP Corrected Wheel Power vs. RPM
Range: 2100 RPM - 3000 RPM
EngSpd: 3000 RPM @3000 RPM
STPPwr: 559.9 CHp @2700 RPM
STPTrq: 1140.8 Clb-ft @2500 RPM
Speed : 76.9 mph @3000 RPM
WhlPwr: 473.2 Hp @2700 RPM
WhlTrq: 964.2 lbs-ft @2500 RPM
Smarty 9 Pressure 2%
COLUMN MAXIMUMS
Test: 33107JuddMcLure2
Range: 2000 RPM - 3000 RPM
STPPwr: 541 CHp @2700 RPM
STPTrq: 1108.5 Clb-ft @2500 RPM
Speed : 77 mph @3000 RPM
WhlPwr: 456.9 Hp @2700 RPM
WhlTrq: 936.3 lbs-ft @2500 RPM
COLUMN MAXIMUMS
COLUMN MAXIMUMS
COLUMN MAXIMUMS
COLUMN MAXIMUMS
ya, i am confised as too why. also with all 3 pulls had an overboost code, which i thought both the mp8 and SMARTY did boost fooling. so i dont know im lost on that.
What is STP Power? It looks like your wheel hp was 473. I see a TST in your sig, so that was without the TST?
Your truck might be one of those that doesn't like the SMARTY all that well. The SMARTY made less power on my truck than the HOT Juice. With HOT Juice, mp-8, and stage 1 cp3 I made 502 wheel hp.
Ok, good. I was worried for you. That was without the TST? What elevation is that at? Don't know much about correction factors. I dynoed at like 950ft so he doesn't bother with a correction factor.
Jethro6213
19
07-11-2008 11:59 AM
lowboy18011
18
12-01-2006 06:46 PM
Doubleover
04-21-2006 02:38 AM
052500#1
13
01-06-2006 03:27 PM
