Smarty Question
Smarty Question
I run the the 4.11 B Moderate Torque Management on my Smarty on level 7. I want to know how long my stock clutch and stock turbo will hold up before they burn up. I was hammerin down (spinnin my tires) the other day and it slipped for the first time and i have since been taking it easy on it! But I love what the Smarty has done to my truck!
I don't really even get what the different TQ management versions do for us manual guys. I mean, if it is designed to de-fuel during shifts.......?
Seems like that would only apply to the automatics, seeing as we lose all boost upon shifting anyway.
That being said, my South Bend DD doesn't seem to mind the "Wild" set on #9.
I would say take it easy unless you are currently saving for a clutch. Driving style is king when trying to stretch out clutch life. Romping on it in 5th, dumping the clutch at 3K rpms and all forms of tire smoking should be avoided if possible.
I run level 7 moderate, have been for quite awhile now. I just don't get into it too soon. I have 77,500 miles on the clock. Still holding strong. Once you slip it once you know what it takes to make it slip, so change your driving style accordingly. The tq managements really just determine the sensitivity of the pedal from 0-100%, and how much fuel is allowed at takeoff.
my still running strong with about 20K with the smarty and about 10K with Wild TM on 7 and i am not very nice to it. but i would turn it down to 5 at the most till you get some gauges or a monitor. if you keep on the way you are it will be sooner than you want that you will be fixing alot more than a clutch and just a turbo. GET Gauges NOW
skydiver41
03-23-2012 08:51 AM
stock03
34
04-21-2011 07:40 AM
jmccart
11-22-2007 07:43 PM
Mike Holmen
05-21-2007 10:21 PM
