Smarty JR on 2004 ?
Smarty JR on 2004 ?
I quickly loaded 5.08 with POD onto my 2004. I set the Sw to 2 with timing and trq to default. I can definitely feel a difference down low and throughout the mid to high. I would like to know will the Smarty change the boost pressure. I still only see the stock level of 23-24 psi. I know the wastegate is manual and not electronic. Some guys must run a boost fooler as well ?
Can someone tell me what the difference is between 5.08 and 5.09 ?
5.09 is suppose to correct TQ2&4 reversal with 5.08 but didn't but did gain smoother running for most of us. That's it. Boost with be a tad higher but you'll have to push it. I see 4psi high then stock at WOT.
Hmm interesting, i see some guys getting like 30-38 psi with just a smarty. Not that i care but just curious. Mine still is only 1-2 psi higher if that on sw 1,2 or 3. It must have something to do with the way the wastgate is actuated. Mind you i see yours is an 06.
I think you are right 055055.9... 03/04 have a manual wastegate that opens at a preset pressure, programming can't change that. The boost elbow is the answer.
Can buy them on ebay. Here's one now....
http://cgi.ebay.com/ebaymotors/DODGE...Q5fAccessories
If you don't want to bid for one just contact the seller and he will sell at around $20. That's how I got mine.
MikeyB
MikeyB
Does anyone have a pic of where the bleed orifice is drilled on the 1/8 brass barbed fitting is ? What size is this hole ? I might just make one. Anyone ?
bmallen
02-29-2004 10:30 PM
Huntindad
02-09-2004 06:45 AM
