smarty + edge comp help
my friend has an 02 2500 ddp2 and (mach 4s not in yet), hot rod vp44, 64 trim turbo, full built suncoast trans, intake, exhaust, edge comp, and smarty my ques is 1st does the edge add timing and should I run timing on the smarty also what suggestions on settings do you recommend? Thanks
i found it best to go to level 5 and drive it for a day or two. play with one setting for a few days and see how it changes, then play with the other setting. if you start adjusting all of the parameters at the same time you'll never know what each change does on YOUR truck!
patience, grasshopper!
lvmknsmoke..
08-13-2009 10:59 PM
mx684
13
07-24-2007 07:52 PM
JD farmboy
05-21-2006 01:04 PM
rockjeep73
03-25-2005 03:34 AM
