smart 4.2 and tst stack??
Old 08-10-2008, 04:35 PM
modified03's Avatar
I have a smarty 4.2 right now and came across a real cheap tst cr 49 with the adjustable rail pressure and everything What settings should I run the tst on I usually leave my smarty on 9 all the time with no problems. I do have an arsen kit on there now that's not in my sig.
Old 08-10-2008, 05:35 PM
DTR 1st Sergeant
soulezoo's Avatar
You are probably not going to see much over 2/0-3/0. Do not use any of the torque settings, that only help to drain the rail and smarty is enough down low anyway. You will have to have a modded cp3 to keep from draining the rail.
More than that, I see you do not have a turbo upgrade. You will need that as well.
Watch your rail pressure and egts closely and watch results. If one or the other gets out of whack, you have gone too far and need to turn it down.
Try smarty on sw 7 and tst on 2/0 standard to start.
Old 08-10-2008, 05:48 PM
modified03's Avatar
the arsen kit will help me from draining the rail but I will still have to get a modified cp3?? a turbo is on the list too
Old 08-10-2008, 05:59 PM
DTR 1st Sergeant
soulezoo's Avatar
You'll know when you drain the rail, then dial it back... the arson kit will keep you ok for now... turbo first.
Old 08-10-2008, 06:25 PM
modified03's Avatar
what would you suggest for a turbo?? I want something to spool quick but i'm still in school so money is a little tight
Old 08-10-2008, 09:21 PM
DTR 1st Sergeant
soulezoo's Avatar
You could look through the classifieds for now and pick up something used for a decent price... just don't get too big a turbo. Stay around the range of s300 variants with a 62mm inducer... if you could find a garrett gt37 that would be the hot setup.
Thiss
10-20-2012 09:15 AM
Topper
03-03-2008 10:17 AM
D.Wiggs
12-27-2006 06:04 PM
mjpalmer
05-19-2005 11:34 AM
Quick Reply: smart 4.2 and tst stack??
