Small shot of nitrous?
Old 02-27-2008, 08:06 PM
BBA
BBA's Avatar
OK just wondering how safe a small shot of nitrous would be on my truck right now? I have stock heads and studs. Going to get get headwork as soon as I can get enough money. There is a pretty big dyno coming up and was wondering if i sprayed a small shot like 50 or so how much it will help or hurt ? Just throwing around the idea i just want to get 500 or more and dont think I will be able to without some laughing gas
Kevin
Old 02-27-2008, 08:12 PM
bnold's Avatar
With twins you are already pushing your luck... I'm running a small shot now with a built head and I am still leary about pushing it!
Old 02-27-2008, 08:14 PM
hotdram's Avatar
Brian, you didn't even need the nitrous to blow your head gasket with a stock head
~Rob
Old 02-27-2008, 08:17 PM
bnold's Avatar
Yep, Stock head with ARPs was not enough to handle 65psi boost (approx 68psi drive pressure) and an easy shot of 80/20 Water Meth
Old 02-27-2008, 09:13 PM
Ronco95's Avatar
Nitrous on a diesel only helps if you are overfueled, correct?
Old 03-01-2008, 08:06 AM
BBA
BBA's Avatar
Well I was thinking I didnt need to but I do have my truck wastegated at 45psi so I never see over that so I didnt know If i would be ok or not.
Old 03-01-2008, 06:12 PM
2141pete's Avatar
you may be over 500 without it.
Old 03-01-2008, 09:41 PM
BBA
BBA's Avatar
I dont think I will be because of the HO pump....I have a SO but i dont know if its good anymore.
Old 03-01-2008, 09:52 PM
Big Blue24's Avatar
Are you running some Source Automotive Twins, or some home brew?
If you have stock clutch, I don't think you can put down over 450 anyway. It will just slip unless you make 500 HP at like 3500 rpm.
Old 03-02-2008, 09:24 PM
mysterync's Avatar
I doubt with a HO pump you'll have enough fuel for Nitrous! Secondly...Your head gasket WILL fail! No drugs unless studded and ringed!
Old 03-02-2008, 09:31 PM
HOHN's Avatar
Nitrous will add HP even if your truck isn't leaving a trail of smoke 10 miles long.
It's simply easier to make power on the bottle than with more boost.
If nothing else, the intercooling effect of a small shot will alone add a modest amount of HP, never mind the oxidizing effect.
I'd discourage advanced timing with ANY amount of nitrous.
jmo
Old 03-02-2008, 09:49 PM
mysterync's Avatar
Hohn, I've seen 3 trucks lacking in the fueling department never accomplish anything worth mentioning on Nitrous. Some Minor power gains , but if your shooting for power goals, i really dont think without fuel your doing much...Maybe 25..50 RWHP.. I may be wrong though! Just throwing out my theory
Old 03-02-2008, 09:58 PM
BBA
BBA's Avatar
25 50hp is really all i was wanting nothing more.
So no nitrous?
Old 03-02-2008, 10:23 PM
HOHN's Avatar
I was just saying Nitrous will always add a little power, even with a small shot. I consider any hp improvement to be "worth mentioning", but then again, i've been pretty small-time in that dept all along. There are at least 100 guys who were over 600hp before I was over 400. Heck, I'm probably not even there yet!
I agree that it's far more effective to add fuel.
But if you're at 485 or so and shooting for 500, even a tiny little shot should get you there--esp with a single charger.
jmo
Old 03-02-2008, 10:32 PM
BBA
BBA's Avatar
Well let me ask yall this where do yall guess me at hp wise? I dont think I will hit 500.
Quick Reply: Small shot of nitrous?
