Small fuel leak
Old 07-29-2005, 09:32 AM
George&cheryl's Avatar
Small fuel leak
Noticed a small fuel leak under my truck, crawled underneath I have a straight fuel line that goes into a braided type line and it appears the leak is coming from where the two lines meet. Anyone Else have this problem? Easy fix?
Old 07-29-2005, 12:29 PM
apache's Avatar
2nd gens are notorious for fuel line failures on the rubber sections between the tank and metal lines by the bellhousing. remember 1 is a suction/delivery line, if you get air, you get a bad running truck. I dont recall any SS lines on my 95 but ?? Most folks invest in some marine grade fuel line for the repairs. It is rated as top notch quality.
Old 07-29-2005, 01:48 PM
infidel's Avatar
The way I deal with leaks in the location you desribe is to run diesel rated hose from the engine all the way back to the tank.
In fact when replacing the rubber fuel lines I always abandon the steel lines for hose all the way. Too many times the steel/braided lines have started leaking later, hose all the way avoids this.
Old 08-06-2005, 08:18 AM
Leak repaired, it was the approximately 3' section of the rubber return line, it was cracked pretty bad.
Old 08-06-2005, 11:32 PM
Dojman's Avatar
I just replaced mine again today. I had done it about two years ago w/rubber fuel line(non-marine)and they were already cracked really bad.
CruisingRam
01-19-2012 04:45 PM
ChicagoSnow
09-03-2007 01:43 AM
Nappy
02-24-2006 07:57 PM
lowtherc
10-11-2005 03:32 PM
dieselcrazy
02-25-2004 11:22 PM
Quick Reply: Small fuel leak
