slave for getrag $$$ ???
Old Jul 27, 2007 | 09:30 AM
swampthang's Avatar
$$$$$ in my carnage of motor mounts braking it also took out my slave so i call up orielys and they want 100.00 is this right or can i find one cheaper ???
JC
Old Jul 27, 2007 | 09:43 AM
Trebor's Avatar
$50 - $95 at www.rockauto.com I can't remember which one I ordered from there but it ended up being a Bendix unit. You also might check NAPA, Carquest, Autozone, Advanced etc.
Old Jul 27, 2007 | 11:00 AM
swampthang's Avatar
well i took the one off of the hydo set up i got from a 97 cummins and the slave fits on to the 91 lines only prob is i cant seem to find where to bleed the system at ???? any ideas
JC
Old Jul 27, 2007 | 03:17 PM
It doesn't have a bleeder. Dodge sells the clutch hydraulics as a kit and does not recommend replacing the slave separately. That said, they will self bleed with a lot of pumping. The air will eventually work its way up to the reservoir on the master.
Old Jul 27, 2007 | 07:54 PM
dpuckett's Avatar
Jack up the front of the truck and pump it about 200 times. Let it sit overnight.
NExt AM, turn the truck around and repeat. It should be drivable now.
Some OEM slaves have an Allen screw that you can use as a bleeder. Aftermarket ones dont have it.
Daniel
Old Aug 1, 2007 | 07:31 PM
swampthang's Avatar
well thats just great!!!! lol anyway if you look up a replacment slave for the 91 it has the lil bleeder thing it is 92 and up that dont have and actual bleeder it seems i guess i will start pumping there has to be a better way than taking two days to bleed clutch hydo
Thanks guys
JC
Old Aug 1, 2007 | 07:59 PM
dpuckett's Avatar
The slave/ master systems from 90, 91, and 92 will interchange. Dont ask how i know.
DP
Old Aug 1, 2007 | 09:21 PM
dieselJon's Avatar
I would buy the kit from Dodge. $$$$ I know BUT so much less hassle too! I bought both the slave and master from OReillys was somthing close to $200 with the slave being more expensive. Wierd, I know.
Jon
Old Aug 1, 2007 | 09:25 PM
Micaiahfied's Avatar
or you could buy the "upgraded" setup from south bend made for a second get and make it work... i don't believe they are much more expensive if at all over the factory/parts store prices.
Old Aug 1, 2007 | 10:43 PM
PapeCAT's Avatar
I bolted a slave/master pedal assy from a 92 right into my '89 with no worries.
Old Aug 2, 2007 | 05:38 PM
swampthang's Avatar
hey thanks guys ya i know you can bolt on the slaves from the other years the problem i have is that the replacment slave i got and put on my lines from the second gen truck was the fact that i can not bleed the system aside from pumping it for 2 days i am looking at after market slaves and parts now to see if i can build a better system like i did on my old 75 dodge that was a auto to standard conversion so i did not have any of the rods and such for it i made a hydo setup for it with willwood parts cost me 250.00 bucks and pushed even the heavest pulling clutch i put in that truck (big block)
JC
NO_SPRK
Nov 1, 2009 10:38 PM
cummer01
May 27, 2004 04:07 AM
Heeler00
Feb 18, 2004 01:52 PM
Strange
Jan 24, 2004 06:45 PM
