what size tire?
Old 01-26-2008, 08:54 AM
mike moore's Avatar
what size tire?
toyo open country m/t 285/75/17(34") on a xd series spy or toyo open country m/t 275/70/18(33") on a xd series spy. the 17x8" spys have 5.5" of backspace,the 18x8.5" spys have only 4.5" of backspace. I just installed my carli 3" lift w/ solid steel steering stabilizer so I know they'll both fit,I just dont want the tires sticking out far from the wheel wells. Help me out,what do you think?
Old 01-26-2008, 10:16 AM
omaharam's Avatar
My vote? Neither tire. With three inches of lift, either tire is going to look way too small. You need a 35 or 37 under that thing. I just got some toyo 285/75/18s(35X11) for mine and that's with no lift. I've been running 315/70/17(35X12.5) and they look really good on stock suspension. With a three inch lift, those tires you mentioned are going to give the truck the same look as stock - which is way too much wheel well space.
Old 01-26-2008, 10:27 AM
nitis's Avatar
they 18s will stick way out with the 4.5 bs 18s look wide and boxy to me anyways get the 17sand if you dont want 35s get the 285 70 17s or if you want a fuller look get hte 295 70 17s they are a touch shorter but a touch widerall deends on what you want
Old 01-26-2008, 03:17 PM
mike moore's Avatar
what size tire?
thanks for the reply. i like the space between the fender and the wheel,i like to see th suspension. i probably will stay 17" either the 285 or 295. Any rubbing ?
Old 01-26-2008, 04:40 PM
omaharam's Avatar
Are you doing an MT again, or an AT?
Old 01-26-2008, 05:54 PM
07-2500's Avatar
Im running a 4" lift with 35"Toyo m/t on 18x10's with 4.5" back spacing. They are sticking out 3/4" beyond my flares. I wanted to give you an idea what this wheel package looks like!
oldwhite12v
03-25-2011 04:28 PM
schoust
10-21-2009 10:09 AM
bigdogtruck
18
11-21-2007 08:09 PM
4RnrRick
02-27-2007 11:25 AM
ValkSmile
01-23-2007 11:42 AM
Quick Reply: what size tire?
