What Size Spacers Will I Need Between The Duals?
Old 10-09-2007, 10:17 AM
Rollin' Smoke's Avatar
what size spacers will i need to put some 295/70/17 nitto terra grapplers under the rear of my truck? a buddy has them on his truck with about a 2 1/2" spacer and they have a BIG gap between them. just curious what some of you have done!!! thanks
Old 10-09-2007, 11:21 AM
bentwings's Avatar
Try here. Great guy. They make all kinds of wheel spacers and adaptors.
http://www.wheeladapter.com/
Old 10-09-2007, 11:49 AM
Patrolman808's Avatar
I had 2" spacers between my 35s and had a good bit of gap. Around an inch at least.
Old 10-09-2007, 12:39 PM
Hired Gun's Avatar
Fred is the man at that site. I run a set for two years on the chevy and they are top notch.
Old 10-09-2007, 02:45 PM
wap
wap's Avatar
I think anything less than 2"s and you gota cut the lugs. Might as well do 305s or 315s with a 2" spacer.
Old 10-09-2007, 04:27 PM
what do you mean by cut the lugs? i wasnt aware of any modification other than the adapters!
Old 10-09-2007, 04:50 PM
Meaning the studs will stick out past the adapters. Measure how long your studs are and that's the minimum adapter you can run without cutting part of the studs off.
Old 10-09-2007, 05:05 PM
i didnt know that......see you learn something every day!
do any of you have any experiences with this tire size combo?
Old 10-09-2007, 05:41 PM
wap
wap's Avatar
Exactly, thank you, I should have been more specific.
I have no experience with the 295s but I do have 305s on my truck. To me the gap is not excessive, but it would look better with 315s
Old 10-09-2007, 06:41 PM
Topper's Avatar
I run 2"ers on my daully with 35's and I think the space looks good. I put on alot of miles loaded heavy and haul heavy with no troubles.
Good luck,
Topper
Old 10-10-2007, 08:14 AM
i agree that the spacer would look better with 305's or 315's......I just dont want a odd looking gap between them ya know!
Number47
0
07-20-2008 07:52 PM
Ernst223
12-19-2007 10:37 AM
QMAN
01-07-2007 11:00 AM
12valve@heart
10-15-2006 12:22 PM
Mechanos
06-27-2004 03:38 PM
Quick Reply: What Size Spacers Will I Need Between The Duals?
