Size of nut on fan clutch ? 92 CTD in W250
Old 07-08-2007, 06:59 PM
rainfade's Avatar
Well I don't have any open end wrenches larger than 1 inch and can't get down in there real well to measure.
So I was hoping someone could tell me the size of this nut before I run to town. It'd be pleasant to get the right part on the first trip just ONCE this weekend.
Thanks,
Brian
Old 07-09-2007, 09:22 AM
BHD
BHD's Avatar
Brian,
I am sure on the size, but if you have an Advance Auto, or Auto Zone close by you can rent the clutch fan wrench set and save yourself some dollars.
Old 07-09-2007, 09:34 AM
Grey Wolf's Avatar
You'll need a 1 7/16ths fan clutch wrench which is thinner than a normal wrench.....
Old 07-09-2007, 07:13 PM
BearKiller's Avatar
Not absolutely positive, as I am going on year-ago memory, but I am pretty sure that the clutch requires a 33MM wrench.
I took some 1/8 x 1 strap iron and welded up a real good one, using a clutch-not-on-a-truck as a pattern.
I also made a wrench to hold the drive pulley still.
Old 07-09-2007, 07:14 PM
1st Generation Admin
BC847's Avatar
>>> DON'T FORGET IT'S THREADED BACKWARD! <<<
Old 07-09-2007, 09:21 PM
Power Ram 250 C's Avatar
I made one out of a piece of steel, works great for me and cheap.
Old 07-09-2007, 11:36 PM
bgilbert's Avatar
36mm.......
Old 07-10-2007, 09:03 AM
timb's Avatar
1 7/16 end wrench and a ball peen hammer and it will come right off. Just smack the wrench with the hammer in the counter clock wise direction.
Old 07-12-2007, 05:50 PM
rainfade's Avatar
Well I rented the wrench set from advanced and they are too big and slip.
I mic'd the new one and it works out to 1.415
Going to just make one but wanted to confirm the nut is lh thread before I yank on it with my home made wrench.
Thanks again,
Brian
Clane
06-02-2012 03:31 PM
2006Mega
03-04-2008 03:31 PM
big jimmy
07-07-2006 01:33 PM
NoSparkplugs
01-04-2006 11:11 PM
Silver
02-14-2005 04:14 PM
Quick Reply: Size of nut on fan clutch ? 92 CTD in W250
