what size nozzles?
Old 01-28-2008, 08:59 PM
kruegerlouie's Avatar
what size nozzles?
looking for advice on what size nozzles to go with on my 06, looking to peak at 700-725hp with sps66,stage 2 cp3,smarty,mp-8,fass150, banks intercooler.
been getting lots of different advice. looking for decent street mannors also, thanks for the help, thinking 120-200hp range
Old 01-28-2008, 09:06 PM
jwb600's Avatar
I was told that about 165hp is the max for a stage 2 pump. thats what I run and I get no cut out or anything driving. I get a little bit if you are setting still and rev the truck up. I have an 06 with similar mods to you other than injectors and it was very close to 700hp on the dyno. I run a little bigger turbo but they dyno about the same numbers
Old 01-28-2008, 09:21 PM
bluechrome's Avatar
The phat shaft with 175hp sticks will have poor road manners and your egt's will be up there. If I were you would get flux injectors from don m. They are the cleanest burning injectors i've seen.
Old 01-28-2008, 11:52 PM
im almost thinkin the sticks i need for 700hp wont be that nice to daily drive, and thought about just installing them in june to sept for comp. and switching back to stock but how would the big turbo act with stock nozzles and just the smarty&mp8????
Old 01-29-2008, 03:52 PM
bluechrome's Avatar
I've seen and ridden ir 700hp cummins with good street manners but it had twins that rocked
oldwhite12v
03-25-2011 04:28 PM
schoust
10-21-2009 10:09 AM
bigdogtruck
18
11-21-2007 08:09 PM
ValkSmile
01-23-2007 11:42 AM
Quick Reply: what size nozzles?
