single stack with hush muffler
Old 10-26-2009, 10:03 AM
mike moore's Avatar
anyone heard a 6 " single stack with a hush muffler? I want to put a single 6" stack on my rig cut just below the roofline,but dont want to go deaf in the process. I plan on leaving the cat,installing a 20" hush muffler,and using grand rocks single stack with internal baffle.I currently have an mprp muffler and it sounds great,but the truck really needs a single stack.Can it be done without being unbearable in the cab.I dont tow to often an when i do its only about 3,ooo lbs.
Old 10-26-2009, 11:47 AM
rich's Avatar
its still gonna be loud even witha muffler these trucks make some noise
Old 10-26-2009, 12:02 PM
mainiac's Avatar
i run that setup. noisy but bearable at all speeds. passengers don't complain too bad. big difference vs not running a muffler. noise has increased since install though.
Old 10-26-2009, 03:35 PM
homewrecker's Avatar
Don't waste your money on the internal stack muffler.They are a joke.I tried them out and they only made the slightest of difference.Not worth the money
Old 10-26-2009, 06:52 PM
mike moore's Avatar
If there is a better method or muffler I'm open for suggestions.I love the stack look,but not if i go deaf every time im in the truck.
Old 10-27-2009, 07:16 AM
05CTDN8's Avatar
If you can find a muffler that will fit (i believe the AERO4040xl or the 5050 will fit) between the down pipe and your 90* you will be fine....but still it gonna be loud!
Old 10-27-2009, 07:59 AM
rich's Avatar
put it a little higher then the cab,is the only thing i can think of to get the noise down
Old 10-27-2009, 12:09 PM
surfram's Avatar
Found these hushpower+stack videos on youtube:
Edited because of profanity in comments section
http://www.youtube.com/watch?v=kY2e_KBVRP4
http://www.youtube.com/watch?v=rUpEbMee3ag
Old 10-27-2009, 12:46 PM
mike moore's Avatar
thanks for videos,gives me a good idea what im in for.they do sound real nice. its tough to get an idea of there actual sound cause no one around here has stacks.
Old 10-27-2009, 01:15 PM
AlCorr's Avatar
Thanks for videos, I was thing of doing something like that, but maybe not now after seeing the videos, too loud for me inside the cab.
http://www.youtube.com/watch?v=y_t7df--i20&NR=1
This is crazy loud inside the cab.
Old 10-27-2009, 08:08 PM
RamWheelsBy4's Avatar
I have a 6" single miter cut stack cab high. I have an Aero Turbine 5050XL between the down pipe and stack elbow. I also have one of the instack mufflers. It is still too LOUD in the cab most of the time. The instack muffler did tone it down a little at cruising speeds, but not much. It sounds fantastic outside, but can be very annoying in the cab at times.
Old 10-28-2009, 01:36 AM
surfram's Avatar
Your truck sounds pretty awesome Ramwheels...
http://www.youtube.com/watch?v=f7sFBICTrdQ
Old 10-28-2009, 08:06 PM
Thanks, like I said it sounds great from outside the cab. Cruising speed is not to bad, but in town it is annoying a lot of the time in the cab.
mike moore
11-08-2009 08:20 PM
coobie
05-08-2008 05:34 PM
coobie
04-02-2008 01:50 PM
crabman
06-02-2003 06:21 PM
Quick Reply: single stack with hush muffler
