Single rear wheel 3500
Does any body know if they will offer a 3500 Regular cab 4x4 with single rear wheels for 04'? I know 03' didn't offer it. I hope they do or I will have to get 2500. I just wish the 2500 had over load springs like 3500.
Re:Single rear wheel 3500
Rob,
First, welcome to the forum. Looks like you are out of luck looking for a '04 R/C 3500 with SRW. For H/D Rams it goes like this:
1. All Reg Cabs have Long beds (allows use of only two wheelbases)
2. All 3500 Long Beds have dual rear wheels (unknown reason)
Checkout www.edmunds.com for 2004 information. Looks like you are "stuck" with a 2500. Good luck.
The Boss Hog
(3/4 of a ton is better than no ton at all . . . ;D)
The Boss Hog
Thanks for the help, thats what I thought. I cant beleive they offer it for quad but not regular, very odd. Is the deference between 2500 & 3500 with HO Diesel just the springs? And if so can I just instal the helper springs.
I think if you do a search on this it has been discussed before. The HO has the same suspension and rear end less the overloads and a lower (dunno this for sure) weight rating. You don't get the cow lights on the roof either(whoopee :. DC probably does not offer it because it is not as popular. The quad cabs are the biggest sellers so they will produce them. HTH
[quote author=Rob1325 link=board=17;threadid=18708;start=0#msg175436 date=1061515163]
[/quote]If your going to buy new then have your dealer build you one...Get a 2500, add cab lamps and the overload leaf kit for the 3500. Then to finish it all off and have everyone scratching their heads have them change the 2 to a 3 in the lettering- easy stick on badges all of which is an easy order for the parts department. You can tell people you have "special" friends at the DC factory
[quote author=JAXFL link=board=17;threadid=18708;start=0#msg176464 date=1061832016]Then I could be a 1500 4x4 HO DSL.
[/quote]Naw!! that just wouldn't be cool, how about slipping a 5 in there for a Ram 5500?
I did add a "Cummins Powered" decal on the tailgate, reads like this now on the drivers side....
DODGE
Heavy Duty
"Cummins Powered"
All are in shinny letters and looks good.
DODGE
Heavy Duty
"Cummins Powered"
[quote author=JAXFL link=board=17;threadid=18708;start=0#msg176762 date=1061901729]
DODGE
Heavy Duty
"Cummins Powered"
[/quote]
Oh yeah get us goin and then no pics.... : ;D
DODGE
Heavy Duty
"Cummins Powered"
[/quote]
I'm not sure you can just "add" the overloads from the 3500 to the 2500. The spring stops are probably welded to the frame and adding them (if you can even get them) would likely void the warranty on the frame.
[quote author=The Boss Hog link=board=17;threadid=18708;start=0#msg175575 date=1061552615]
Rob,
[/quote]
Boss, my 3500 is a long box and it has single rear wheels.
Rob,
[/quote]
