silencer ring
Old 01-02-2005, 07:28 PM
ftltmp's Avatar
Question silencer ring
I ttried to remove my silencer ring today, any advice on getting the snap ring out without damaging anything? thanks
Old 01-02-2005, 08:59 PM
Kyle Graham's Avatar
screwdriver and needle nose pliers use a flathead screwdriver to pry it up just enough to grab it with plier's it would be pretty tough to hurt anything remove the snap ring and silencer ring will just fall out
Old 01-03-2005, 01:58 AM
Raspy's Avatar
Use a small flat screwdriver that will catch on the tapered end of the snap ring. Pry it up just enough to get another small flat screwdriver to slip under it. Now you are started. Work it up with both drivers till you can grab it with a needle nose plier and lift it from it's groove and free it. Lift out the ring.
Wetspirit
Old 01-03-2005, 08:55 AM
GotBoost?'s Avatar
Re: silencer ring
WD-40 will be your best friend!
Of coarse use a good cleaner afterwards to get the wd-40 out.
I did that and used some dykes to get it out and it slid out like butter.
Old 01-03-2005, 09:09 AM
Barefoot88's Avatar
where is this located at
Old 01-03-2005, 09:54 AM
when you remove the intake tube off your turbo it will be staring at you the silencer ring is the tapered ring infront of the impeller remove black snap ring and tapered ring will slide right out
RonP
02-17-2010 09:30 AM
RRC
05-13-2007 11:45 PM
HaulinBut
05-12-2006 03:06 PM
StrokeThis2500
12-31-2005 05:19 PM
Quick Reply: silencer ring
