silencer ring
silencer ring
well after about 30 mins of working, i couldnt get the c-clip out, i tried prying it up and grabing it with a pair of needle knose, but no luck
any suggestions?
any suggestions?
keep trying, i got mine out after about 1000 tries. i used a small pocket screwdriver under the beveled end of the lock ring and then got another screwdriver under it and it shot out over my right shoulder.
does it make any more power or just sound?
or both?
I read somewhere about bad pressures that can hurt the turbo after the ring is removed? any truth to this?
or both?
According to Holset, it's an inlet baffle. I used to think it was simply to reduce sound, but since I've seen it on bigger holsets (HX40s, 50s, 55s) I believe it actually smooths out the flow into the compressor. More laminar flow should increase compressor efficiency.
But I still run without one
The silencer ring can also (I've heard) inhibit flow from the MWE on turbos with small exhaust housings.
Apparently I've removed too many C-clips growing up on the farm cause that was a piece of cake. Took me longer to get the intake tube off. I didn't notice all that much difference except that I can hear the turbo spool earlier and I lost some of the turbo whistle. I'll probably be used to it by the time I make the drive to skool tomorrow...
RonP
02-17-2010 09:30 AM
RRC
05-13-2007 11:45 PM
