Is this the sign that the clock spring is going?
Old 06-30-2007, 02:51 AM
bigragu's Avatar
My horn only works when the steering wheel is turned towards the right. I posted a while back that my CC switches have no power going to them, therefore no cruise control. Is the horn thing pretty much saying that it truly is on its way out for good? These are a $150.00!
Old 06-30-2007, 06:08 AM
Yep. The next sign you get will be crunching noises accompanied by a binding steering wheel.
Old 06-30-2007, 12:31 PM
92DuallyCTD's Avatar
...Yep. And the NEXT sign you get will be even BIGGER crunching noises when the steering wheel does bind!! But seriously...hmmm, seriously is too difficult for me...but really(that's better...) I'd be gettin' to that right quick! I think steering is #2 on the list of what should work best on a truck(#1 is brakes of course).
Old 06-30-2007, 05:03 PM
NoSparkplugs's Avatar
Well I think I have this problem then too since my borgerson shaft was slipping on the shaft (long story) and I heard some crunching sounds. Well local dodge dealer... here I come
Old 06-30-2007, 05:48 PM
Jim Lane's Avatar
My horn does not work but my cruise control still does. I guess it can be selective.
Last time I checked at my Dodge Dealer unless 1991 is diffrent that your 1993.
Clock spring for horn and cruise control #4688655 $109.00
Jim
Old 06-30-2007, 05:58 PM
Flake's Avatar
My clock spring was junk when I bought my truck.
I went to the Pull&Save yard and replaced it with one from a 1994(I think) Plymouth Sundance, it had all the same connections plus a wire for an airbag which I just cut off.
Grand total $5, it's been working perfectly for the past 3.5 years.
Old 07-01-2007, 07:22 AM
bigragu's Avatar
This is what I was looking for( thanks a plenty still to the rest of you, and Lane for the part numbers) because a clockspring from NAPA which is for the later years is $50.00, so now I know it will work.
Old 07-01-2007, 12:43 PM
dpuckett's Avatar
I that the later year trucks or cars? I'd assume there is some variations of when what style stuff got introduced into what. (i.e. radios, clocksprings, etc. I know a radio from some 01 cars wont fit in the 01 pickups.)
DP
94 dodge
05-04-2007 10:46 PM
vavtx
01-07-2006 06:47 AM
DieselNomad
06-15-2005 07:34 PM
Flake
06-01-2004 04:05 PM
Quick Reply: Is this the sign that the clock spring is going?
