shutting the waste gate.
Old 01-13-2010, 01:31 PM
1bad93's Avatar
im putting a hx35/40 hybrid on my truck soon and was wondering how could i shut the wastegate, but still use it if i get too much boost. really i want the waste gate to not open but if i change my mind i could still get it to open. the guy i bought the turbo off of said he zip tied the waste gate shut. if this is possible. how do you do it? thanks
Old 01-13-2010, 01:35 PM
unixcowboy's Avatar
If you've got a wastegate on it you should be able to adjust the spring tension to adjust when it opens.
Connect the wastegate and see IF it opens. Adjust the spring tension to get the psi you want.
I had to drop mine from over 55 down to 47 and I think that may be too high for the stock head bolts.
Old 01-13-2010, 01:39 PM
1bad93's Avatar
i thought the factory holset turbo wastegates were fixed to a certant boost?
Old 01-13-2010, 01:43 PM
Yes an HX35 is fixed at like 24 psi i think. something low. Its a vacuum diaghram.
Just wire it closed and see what boost you hit...
like a banks big head w/g actuator will be adjustable up to like 40 psi...., or a $10 boost controller like Dave has
Old 01-13-2010, 01:49 PM
PapeCAT's Avatar
I'm not sure about the tie wrap I think it would melt? I have used a hose clamp though and it works fine.
Old 01-13-2010, 01:53 PM
1bad93's Avatar
could you possible show me a picture on how you hooked it up?
Old 01-13-2010, 03:23 PM
dillenger1's Avatar
use a j-hook turnbuckle.Or for adjustments use a air regulator/needle valve
Old 01-13-2010, 03:28 PM
A.K.A
boost controller
Old 01-13-2010, 03:51 PM
1bad93's Avatar
A.K.A
boost controller
i tried to find a boost controller like daves but the only ones i could find were only good to 30lbs of boost.
Old 01-13-2010, 04:51 PM
1bad93's Avatar
ok well that is solved. i found a adjustible boost elbow for my turbo made for diesels. so thanks for the info guys.
Old 01-13-2010, 05:30 PM
bullfrog5.9's Avatar
i hav a WH1 C and i wired the waste gate shut and now i hit 30psi with out any fuel turns
Old 01-13-2010, 06:18 PM
92smokin blacky's Avatar
use a tight spring that you can adjust like a j-hook that you can buy for the hy turbos. Or use a turnbuckler that will keep it shut. I use both on my he351, use the turnbuckle when i don't want it to open, and put the spring on if i want it to open and i can make it open later by tightening the spring(its actually a j-hook for an hy35, but it works)
Old 01-13-2010, 09:54 PM
14racing's Avatar
Hmm... thats interesting. The housing i took off the WH1C i bought has an adjustable wastegate actuator.
Old 01-14-2010, 06:33 AM
Yea that is interesting, I'm thinking banks big head.
The HX35 i have here on the bench waiting to go on the 93 is definely not adjustable.
Old 01-14-2010, 02:10 PM
Mark Nixon's Avatar
Pull cable it.
Then you can adjust it manually, if you need/want to.
Mark.
Quick Reply: shutting the waste gate.
