Shut off solenoid replacement
Old 01-03-2007, 11:10 PM
mhuppertz's Avatar
Can I put a normally closed solenoid valve on the fuel line going to the injection pump? Then I could chunk my worthless shut down solenoid and plumb in an extra fuel line!
Old 01-03-2007, 11:12 PM
Begle1's Avatar
Don't see why you couldn't...
My idea was to attach a servo onto the manual shut off.
Old 01-03-2007, 11:15 PM
mhuppertz's Avatar
I thought about that also, maybe using a starter solenoid, but I haven't found a way to rig a momentary switch to my cool down timer...
Old 01-04-2007, 05:15 PM
That would be bad for the pump.
Begle's idea is better.
OMG, what have I done! I can see that quote in his sig now.
Old 01-04-2007, 06:50 PM
Begle1's Avatar
How would it be bad for the pump?
Old 01-04-2007, 06:52 PM
mhuppertz's Avatar
I wouldn't be introducing any air into te system, so no components would run dry would they?
Old 01-04-2007, 06:59 PM
AAmeeting's Avatar
I have used this for car audio actuators, push a button and it latches not a momentary here's the site www.selectproducts.com search "latching" $15.60 for the latching relay assembly, it will work. Woodford reserve is pretty strong... as it were, i am out.............
Old 01-04-2007, 07:22 PM
loch's Avatar
With a normally closed valve when you shut it down its going to starve the IP, it probably wont die instantly. When the fuel in the IP is used it will die. Problem I see is loss of lubrication when IP is starved.
Dave why in the world would you agree with him ? We are never going to hear the end of this, your an admin, go delete that quick.
Old 01-04-2007, 07:35 PM
Begle1's Avatar
Doesn't the pump starve just almost as much with the stock solenoid?
Old 01-04-2007, 08:08 PM
Boatnik's Avatar
Just join the pull cable club and be done with it.
Old 01-04-2007, 08:11 PM
Begle1's Avatar
But it'd be mur pimpin' if I could push a button and have something pull the cable automatically.
Old 01-05-2007, 04:38 PM
No. The stock solenoid just stops fuel from going from the main case into the distributor head.
Old 01-05-2007, 04:39 PM
So you wouldn't want it to turn off with the key?
dkimmel
01-03-2011 10:54 PM
randyswelding
02-09-2009 10:40 PM
skywalker175
05-13-2003 02:37 PM
doomgaze
12-12-2002 05:18 PM
Quick Reply: Shut off solenoid replacement
