Should I Go With 370hp Injectors?
I have been looking at geting new injecters and saw the 370 marine injectors for around $400. I only have a #10 plate and don't want super high egt's or excess engine wear, I want this truck last.
So 300hp, or 370's?
So 300hp, or 370's?
even with a stock turbo its drivable with 370s, but ur egts will be toasty if you get on it.. Man they sure are a nice kick over stock thats for sure
Rick
I would look at one of the "built 370s" like new era's injectors or piers. They will be alot better running than the standard ol bosch 370.
http://www.neweradiesel.com/
http://www.piersdiesel.com/
Piers runs Bosch 370's and they are the marine version.
New Era has 370's that Chuck (the owner) does himself.
Marine ones have wrong spray angle and get hotter than regular spray angle.
Lance
Lance
From experience i can tell you that I definitely prefer the new era 370s over the pdr370s. The new eras are 380 if you send your stock ones in for cores, or 480 if you want to just keep your stock ones.
I am gonna buy some 435s from new era before summer..
I already have good top end but not much take off. Just wondering if the 370's are too much for me and my mod's?
Thanks, that's the kinda stuff I'd Like to know before I buy. I'm still a little concerned about the heat with a stock turbo and no head studs. Like I said before, I'm not looking for sled power, just good even power.
timing and stock injectors are kinda lame, stock timing with stock injectors is cool, the 370s will get u a nice gain down low, but with a stock turbo, not much more u can do with them.... egts will get hot on a stocker if you get on it hard.. But if you drive sane, they are a nice 0-60 or so blast... But they are still fun, i had them like that
Rick
On Edit: Wilderness, have you adjusted your star wheel? Just a thought.
1 Post
you can get 370s from citydiesel.net for 300 bucks. that is where I got mine. they are good guys, I don't have a problem with the injectors like a lot of guys do. they are new 370 bosch units.
schamran
04-01-2012 07:47 AM
tywebb3
06-23-2006 11:30 PM
