What should the fuel pressure be at idle and Wot did search could not find
Old 10-12-2006, 02:00 AM
QWKRTNU's Avatar
What are the correct fuel pressure psi's. I got 10psi at idle and 6 wot with my edge on level 5. Thanks
Old 10-12-2006, 02:04 AM
morkable's Avatar
I take it your just running the factory fuel system?? I get pretty much a steady 15psi with mine (Fass) It only drops maybe 1psi
Kevin
Old 10-12-2006, 02:08 AM
QWKRTNU's Avatar
yes it is the factory system what is safe to fun before I need a fass or walbro pump.
Old 10-12-2006, 02:18 AM
morkable's Avatar
welllllllll,,, 6 is allready low,, but I have heard guys getting down to 1,, but man o man that is taking your cp3 for granted,, they are not cheap/easy to replace. I think that if it dosent get any lower than say 5 you should be ok,, but I would start to worry around that level
Kevin
Old 10-12-2006, 08:55 AM
Luken's Avatar
I would put a GDP kit on it and then you won't have to worry about it
Old 10-12-2006, 10:45 AM
qzilla's Avatar
The 05-06 truck should run 6-7psi. They are a low pressure high volume pump. 6-7 psi is listed as the proper pressure from the factory.
Old 10-12-2006, 12:46 PM
deezulsmoke's Avatar
Mine runs around 7-8 psi at idle, I can pull it down to almost zero with the ts ramifier.
84mphcdt
05-24-2009 11:38 PM
HOHN
42
04-22-2006 06:31 PM
CACalomino
05-18-2005 08:55 PM
Diesel Dave
06-18-2004 09:47 AM
hellotbone
16
03-31-2003 08:28 PM
Quick Reply: What should the fuel pressure be at idle and Wot did search could not find
