shorted solenoid
Old 11-12-2008, 08:49 PM
upersleder's Avatar
shorted solenoid
last night my truck would not start, no power electrically, after playing awhile it looks like one of the solenoids on the drivers side fender shorted out. i think these are for the grid heater. after unhooking the wire for the solenoids i was able to charge the batteries and get started again. can i put any solenoid on in its place? what are my options? how do i test the grid heater to make sure is did not short out also? THANKS GUYS
Old 11-12-2008, 11:33 PM
johnh's Avatar
i have a ford starter solenoid installed on mine .it cost about 8.00
i try and find the part # in the morning
Old 11-13-2008, 12:08 PM
george7941's Avatar
Here is the Ford relay mentioned above
http://www.rockauto.com/catalog/raframecatalog.php
However, it is not a straight bolt-on. If you can do the work necessary to mount this Ford relay, then by all means install the much cheaper Ford relay.
As for testing the grid heater, a sensitive multimeter will be able to measure the 0.1 ohm resistance of each of the grid heater elements. Else you can use a clamp meter to measure the 90 amp current thru each of the elements.
Old 11-13-2008, 04:37 PM
patdaly's Avatar
You have to make sure the solenoid is ground isolated, otherwise as soon as you hook up the 12V to the coil it will drag in and stay in.
I started that way until I found the correct relay for 50ish bucks from rock auto.
Good luck.
Old 11-13-2008, 05:22 PM
johnh's Avatar
Old 11-13-2008, 07:16 PM
george7941's Avatar
Good luck.
That is strange. On my Freightliner truck, the ECM activates the grid heater relays by feeding 12v to the relays, not by grounding a terminal on the relays. I just checked the Cummins Factory Service Manual and it shows the ECM supplying 12v to the relays, so I doubt that the Dodges are different from the Freightliners. Relays with grounded bodies should work, so the $14 relays from Rock Auto should be all that is necessary.
Old 11-13-2008, 10:40 PM
johnh's Avatar
the part number is it the picture, the solenoid wires up the same as the dodge unit.
if i remember right, i had to splice more wire on the trigger wires.... it won't mount exactly the same either
Old 11-16-2008, 10:52 PM
upersleder's Avatar
thanks guys, hope to have it fixed soon, getting cold here, but hunting came first
Bad Ramer Jamer
142
08-18-2018 04:24 AM
vanman59
08-31-2009 06:45 PM
NOTA HEMI
01-22-2008 10:26 PM
Iron City
11-03-2005 08:31 PM
Quick Reply: shorted solenoid
