shortbed dually
for others thinking about swapping we had three axles on the gargage floor ...
the cab and chassis was 1" narrower PER SIDE than the SRW ...
which was in turn 1" narrower PER SIDE than the DRW pickup axle
freinds are amazed at how much better it handles than when it had 35's
and how much rougher it rides with doubled springs and 4 ten ply tires
Wow, just what I was looking for....... do you have any Numbers for widths on those.
I'm still trying to positively identify the disked D80 I recently picked up.
I second the mega cab flares I'd love to have a set of them on mine wonder if the boby lines are close enough to make it look decent?
I do like the c&c rear under there I thought frame was narrower on c&c and tires would rubb the springs.
Jed
Jed
Demon ... sorry don't remember the widths ... but you aught to be able to just measure the distance from the spring pads to the backing plates on your truck and compare to the 80
linetrash79 ... frames are the same width ... at least on my father in laws '01
See he's the thing....... no ones been able to tell me where the width difference is found.
Is it in the axle tube length? (pumpkin to backing plate) and the hubs are all the same.
Or are the axle tubes all the same and the hubs are different widths......
I know the GM corp 14bolt FF has interchangable hubs.....from single wheel to DRW
i had a srw dana 70 ... so the hubs were different
the two drw axles that we had were both '96 model dana 80s
so were identical except for the axle tube lengths ...
this probably doesn't help you but i thought i'd throw it out ...
good luck and post whatever you find ...
