shifting after washer mod
Old 01-07-2008, 09:17 PM
jknowles4's Avatar
In an auto tranny, when should the truck shift after the washer or 3k spring kit is installed. If I manually shift it it stops pulling about 3200rpm, but if I let it shift itself, it shifts at about 2400 rpms. Is this right or should I tighten the springs a few clicks? This is in a stock tranny.
Old 01-07-2008, 11:50 PM
displacedtexan's Avatar
The governor springs won't change the shift points.
Old 01-08-2008, 02:08 AM
wcbcruzer's Avatar
You gotta change out a spring in the valve body to make it shift later under hard throttle.
Old 01-08-2008, 12:18 PM
jknowles4's Avatar
That's what I thought guys. Thanks!!!
squirrel
07-14-2008 11:28 PM
turbos10
02-16-2008 10:57 AM
jknowles4
0
01-06-2008 10:51 PM
turbos10
10-06-2007 11:32 AM
NorKal12valve
07-12-2007 07:59 AM
Quick Reply: shifting after washer mod
