Shift firmness question
Old 08-07-2009, 12:58 PM
dodgeramit1's Avatar
I have my shift firmness set to mild for my dtt trans. It still jerks back when it shifts from 1st to 2nd and then a little bit for 2nd to 3rd. Is there any thing i can do to make this less noticable? (Its made my girlfriend kinda nervous everytime she gets in my truck and she complains...alot.)
Old 08-07-2009, 01:12 PM
Ram Daddy's Avatar
Wink
...get rid of the girlfriend
Old 08-07-2009, 01:18 PM
PCM
PCM's Avatar
I know what you mean. I think that the "jerkiness" is a good sign that the tranny is tight and in good shape. I don't think anything can be done about it. My '06 is the same way. I used to own a large diesel pusher rv with a big block Cummins and 6 speed Allison. The shifts on it were the same way. I think is is just a characteristic of the heavy duty trannys. I know this isn't much help other than to let you know it's "normal". pcm
Old 08-07-2009, 02:04 PM
Thanks pcm. I had heard something somewhere about something from ts preformance. Has anyone heard about that?
Old 08-07-2009, 07:54 PM
Moneywoes's Avatar
Probably thinking of a Shift enhanser, TS performance and DTT both have one. As I understand it these are used to help with the 1-2 and 2-3 shuttle shifts and 1-2 flair shifts that some of us get with low throttle input shifts on a built trans. I may be wrong, but I don't think a shift enhanser will help with shift "Firmness" I think shift firmness is dependant on how your VB was set up by the builder.
Old 08-08-2009, 08:34 AM
omaharam's Avatar
It took Bill and John 3 attempts between them discussing (arguing) about what I wanted, but finally John got a the VB to still provide adequate pressures without slamming into gear. My truck only shifts slightly more firm than stock unless I'm pulling a heavy load - then you can feel it a lot more. So it can be done with the correct Vb set up, but it would cost you more money at this point.
Old 08-08-2009, 08:03 PM
And thats money i dont have at the moment. I dont know about the trans. itself, but the tc was set up to provide the best pulling power possible. Mine was, or the way i took it, set up to provide the best power to the wheels possible. In other words, power instead of comfort.
Old 08-08-2009, 08:17 PM
RickCJ's Avatar
You can change springs in the valve body to make it shift however you like.
Old 08-08-2009, 08:26 PM
How much does that cost? Is it hard or just a pain in the butt?
Old 08-08-2009, 08:28 PM
RickCJ's Avatar
Springs are cheap but labor costs?
Old 08-08-2009, 08:35 PM
Ok thanks. I guess untill i have the money, shes staying like she is.
Old 08-08-2009, 08:38 PM
omaharam's Avatar
That's not necessarily true. It depends on other factors such as the holes drilled in the separator plate, number of clutches in the packs, etc. I had a Goerend VB when I first had extra clutches added, and no matter what was tried, it shifted like a ton of bricks. Had to start with a completely different VB to soften it up.
itr.#1446
11-09-2008 09:03 PM
MoparRiggan
29
11-09-2008 12:02 AM
poogan
05-04-2007 08:47 PM
wreedCTD
04-05-2007 11:49 PM
CASMOKIN
Competition / Pulls / OffRoad
12-30-2005 01:28 PM
Quick Reply: Shift firmness question
