View Full Version : shaking of truck
bootsdodgejn
12-19-2007, 12:20 AM
Going down the road between speeds 40-65, I get a shake of the truck like i am going over multiple speed bumps. Its bee goin on since i got new track bar. Now it fell like im going over rumble strips, but not all the time. Any idea..
paroxysym
12-19-2007, 01:14 AM
make sure your trackbar is tight. did you get an alignment after you installed it??
bootsdodgejn
12-19-2007, 01:30 AM
yes an alignment was done
Festus
12-19-2007, 03:13 AM
Ahhhh...........the dreaded death wobble. Many a thread on this for you to search. Shocks and DSS solved my OEM DW woes.
getblown5.9
12-19-2007, 08:28 AM
luckily ive never had DW (knock on wood) but check and double check that the track bar is tight!!!
bootsdodgejn
12-19-2007, 08:34 AM
yea im goin to school and puttin it on a lift and checking it. also searchin the other threads
JonnyThrottle
12-19-2007, 12:15 PM
tighten the trac bar and make sure your tires are balanced.
might want to check the alignment again if that didnt work. They might not have done it right
vBulletin® v3.6.7, Copyright ©2000-2010, Jelsoft Enterprises Ltd.
